Ga door naar hoofdinhoud
8BitDo Ultimate Wireless Joystick Cover Replacement
Wat je nodig hebt
  1. 8BitDo Ultimate Wireless Joystick Cover Replacement, Case: stap 1, afbeelding 1 van 2 8BitDo Ultimate Wireless Joystick Cover Replacement, Case: stap 1, afbeelding 2 van 2
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Vraag FixBot
    Voeg opmerking toe
  2. 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 2, afbeelding 1 van 2 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 2, afbeelding 2 van 2
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Vraag FixBot
    Voeg opmerking toe
  3. 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 3, afbeelding 1 van 3 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 3, afbeelding 2 van 3 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 3, afbeelding 3 van 3
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  4. 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 4, afbeelding 1 van 3 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 4, afbeelding 2 van 3 8BitDo Ultimate Wireless Joystick Cover Replacement: stap 4, afbeelding 3 van 3
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  5. 8BitDo Ultimate Wireless Joystick Cover Replacement, Joystick Covers: stap 5, afbeelding 1 van 1
    • Grip each joystick cap firmly and pull straight up to remove them.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
473 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 Lid van UMass Dartmouth, Team 1-3, Biswokarma Spring 2026
UMASSD-BISWOKARMA-S26S1G3
5 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 61
Altijd: 149
