Inleiding
If your 8BitDo Pro 2 controller D-Pad is unresponsive or not registering inputs correctly, the D-Pad may need to be replaced. This guide will walk you through removing and installing the D-Pad on your controller.
The D-Pad is responsible for directional movement and input control during gameplay. Over time, wear and tear can affect the performance and responsiveness.
Before using this guide, try cleaning around the D-Pad to ensure proper function. You should also test the controller on different devices to ensure it is in the correct input see the troubleshooting page for more information.
This guide will require you to open the controller. Before beginning, make sure to power the controller off.
Wat je nodig hebt
Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
Remove the six, 10.0 mm Phillips #00 screws along the edge of the main board.
Remove the 5.0 mm Phillips #00 screw towards the center of the board.
Pull the main board from the top case to remove it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
