Ga door naar hoofdinhoud
8BitDo Pro 2 Action Button Replacement
Wat je nodig hebt
  1. 8BitDo Pro 2 Action Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
    Vraag FixBot
    Voeg opmerking toe
  2. 8BitDo Pro 2 Action Button Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery cover off to remove it and expose the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. 8BitDo Pro 2 Action Button Replacement: stap 3, afbeelding 1 van 1
    • Use your hands to remove the battery pack from the controller.
    • Do not bend or puncture the battery pack, this can be hazardous.
    Vraag FixBot
    Voeg opmerking toe
  4. 8BitDo Pro 2 Action Button Replacement, Controller: stap 4, afbeelding 1 van 1
    • Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  5. 8BitDo Pro 2 Action Button Replacement: stap 5, afbeelding 1 van 1
    • Use a T6 Torx screwdriver to remove the four 5.0 mm screws from the back of the controller.
    Vraag FixBot
    Voeg opmerking toe
  6. 8BitDo Pro 2 Action Button Replacement: stap 6, afbeelding 1 van 3 8BitDo Pro 2 Action Button Replacement: stap 6, afbeelding 2 van 3 8BitDo Pro 2 Action Button Replacement: stap 6, afbeelding 3 van 3
    • Insert the iFixit pick into the seam along the edge of the controller and slide it around to release the clips holding it together.
    • Leave opening picks in the space to keep the top and bottom case from reattaching.
    • Use an iFixit tool to carefully pry around the edges of the controller.
    • Once loosened, gently separate the top and bottom of the controller.
    • Do not separate the top and bottom sections, as they are still connected by a ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  7. 8BitDo Pro 2 Action Button Replacement: stap 7, afbeelding 1 van 2 8BitDo Pro 2 Action Button Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to gently push up on alternating sides of the black plastic tab until it clicks up into its unlocked position.
    • Don't push the tab too hard or too far, otherwise it may come completely off the connector.
    • Use tweezers to gently pull the cable out of its socket.
    • The cable should be able to slide in and out of the socket with little to no force. If you feel resistance, the tab may not be fully unlocked.
    • During reassembly, insert the cable into its socket and use the flat end of a spudger to push the tab down into its locked position.
    • Separate the top and bottom casing of the controller.
    • If you feel resistance, check for any cables still connecting the two halves and avoid forcing them apart.
    Vraag FixBot
    Voeg opmerking toe
  8. 8BitDo Pro 2 Action Button Replacement, Action Button: stap 8, afbeelding 1 van 3 8BitDo Pro 2 Action Button Replacement, Action Button: stap 8, afbeelding 2 van 3 8BitDo Pro 2 Action Button Replacement, Action Button: stap 8, afbeelding 3 van 3
    • Remove the six, 10.0 mm Phillips #00 screws along the edge of the main board.
    • Remove the 5.0 mm Phillips #00 screw towards the center of the board.
    • Pull the motherboard from the top case to remove it.
    Vraag FixBot
    Voeg opmerking toe
  9. 8BitDo Pro 2 Action Button Replacement: stap 9, afbeelding 1 van 1
    • Gently pull the conductive rubber cover from the action buttons.
    Vraag FixBot
    Voeg opmerking toe
  10. 8BitDo Pro 2 Action Button Replacement: stap 10, afbeelding 1 van 1
    • Push the action buttons out of the top case to remove them.
    • You may hear a clicking sound as the action buttons are removed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Paige Lucas
563 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-3, Rioux Spring 2026 Lid van UMass Dartmouth, Team 5-3, Rioux Spring 2026
UMASSD-RIOUX-S26S5G3
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 40
Altijd: 69
