Irremovable Marks on Screen
Hello, I've been using a 14" Macbook Pro for a little over six months now, and I've noticed some marks on my display that, no matter how much I try to clean off, look to be permanent. I've used "Whoosh!" screen cleaner and 70% isopropyl alcohol, but there's always some marks left, sometimes even visible at high brightness. I think it's worth mentioning I sometimes use my laptop closed for long periods of time, potentially exposing the display to higher than average temperatures. Although I've heard that this is safe, I feel that this could have contributed to this. Has anyone else experienced this? How can I get rid of them and prevent them from re-appearing or getting worse? Thank you.
Is dit een goede vraag?
3 opmerkingen
hmm could be the antireflective coating wearing off because of the heat somehow although its unlikely. It could ofc also be the keyboard leaving imprints on the screen but we'll need pictures to confirm : Voeg afbeeldingen toe aan een bestaande vraag
door Leooooo1061 Deel
A photo taken at an angle with the screen off and a bright light reflecting across it would help a lot here. If the marks line up with the key rows, it is usually contact imprinting rather than heat, and a thin microfiber sheet between keyboard and screen when closed can stop it getting worse. Since it is only six months old, it may also be worth asking Apple to look at the coating before trying anything more abrasive.
door Jesse M. Hoffer Deel
@leooooo1061 I've attached a couple images to the post. The keyboard imprint as well as some marks outlining the trackpad are definitely visible under a light.
door Shawn Lee Deel
