Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht op 20 september, de reguliere 2019 iPhone van Apple wordt geleverd met een 6,1" LCD-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
Unexpected working on speaker
I purchased a second-hand iPhone 11 and replaced the screen and the battery. I’m not certain if this started after the replacements, but when someone calls me, the ringtone plays, then stops after a while, starts over, stutters, and so on. Sometimes, there is no sound from the phone at all. Similar stuttering issues also occur within the ringtone selection menu. Could there be an issue with the battery? I have already tried a clean install, but that did not resolve the problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Sounds like a speaker issue to me. If you followed the iFixit Battery replacement guide then you took the speaker out during the repair, and I'm wondering if there's an issue with its connection.
The speaker gets its signals from two copper contact points on the charging port flex cable, circled here in this image.
Afbeelding
You'll need to open the phone back up and pull the speaker. Check to verify there isn't anything blocking either of those pads, then check the spring pins on the speaker itself to verify they're not bent or broken. Here's a picture of those.
Afbeelding
If that doesn't help, you might want to just go ahead and replace the speaker; they're not particularly expensive if you shop around on sites like AliExpress, eBay or Amazon.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Semih S. Avcılar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 23
Altijd: 23
