Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De XV20-serie van de Toyota Camry is de 6e generatie Camry-sedan van Toyota.
Code P0758 Camry 1998 V6
Hi everyone! I have a 1998 Toyota Camry V6 with Automatic transmission. I’ve got a Check Engine light with code P0758 wich means Solenoid B Electrical. The car is originally from California and drove 41 000 miles there before it got imported to Norway in 2007. It has only drove 42 000 miles since then here in Norway, so I find it difficult to see a problem with the wirings. Does anyone have experienced kind of the same problem and help me out?
Camry Owner.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @vebjoernbek4505
The car is approx. 28 years old so a wiring problem is not out of the question. The wiring could fail for any number of reasons e.g. corrosion, wiring fatigue etc.
Here's the P0758 diagnosis and repair procedure from the service manual, that may help.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hi! I did som research and found out that the S2 terminal in the transaxle connector is OL, and the manual then says «replace the transaxle sub-harness as needed». I can’t find the part number for this specific part (sub-harness). Can you help me out? I’m starting to realize that this sounds expensive if I have to use specialists…
door Deel
@vebbe11
Try this website and see if you can find it.
door Deel
Voeg je antwoord toe
Vebjørn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 41
Altijd: 60
