Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De PSP 3000 werd in de VS uitgebracht op 15 oktober 2008.
Problem, need help with psp
Afbeelding
hello i tried last month to get a new psp for donor parts and it came in today but unlike the other damaged motherboard it wouldnt let me charge (i tried to change the charge adapter) and have tried looking online for psp motherboards replacements but couldnt find any, anyone know the exact model of this psp motherboard and where to get a working replacement?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
We cannot say for sure without the motherboard model name (example: TA-090). It should be on there, can you find it? And is it also possible to upload a picture from the other side?
This is most likely an PSP 3000 motherboard so far I can see (when you check the battery on the board, it matches with other 3000 series board). But I cannot guarantee this.
Here you can determine which TA-0XX model motherboard belongs to an PSP2000 and PSP3000 > https://world.taobao.com/lang/en-us/good...
Regarding buying a new motherboard, the only way I know is through AliExpress.
Example: https://www.aliexpress.us/item/325681270...
Or: https://www.aliexpress.us/item/325680934...
Or: https://www.aliexpress.us/item/325681252...
Please let me know if you have any other question!
Thank you!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Nimeni Phrog zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 45
