Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de Joy-Con 2-controllers van de Nintendo Switch 2.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Afbeelding
Afbeelding
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Afbeelding
Afbeelding
Thank you for reaching out!
Is dit een goede vraag?
2 opmerkingen
Hi!
Glad that you figured it out :)! Have a great day!
door Deel
Thank you! I was about to just accept I busted my controller until I found this.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
Please follow this to step 13: Joy-Con 2 (links) joystick vervangen
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
David Sandoval Galiana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 83
Altijd: 133
