Ga door naar hoofdinhoud
De Meta Quest 3 mixed reality-headset werd uitgebracht op 10 oktober 2023 en is de directe opvolger van de Meta Quest 2 en in veel opzichten de spirituele opvolger van de Meta Quest Pro.
Update and restart loop
I have bought this device used, so I have no warranty.
The device keeps updating and restarting, side load update didn't work because the site said incompatible device or something like that, and factory reset didn't work either (it reseted and still had the loop).
Is there some different manual way to fix that, maybe somehow completely wiping the quest 3's SSD and manually installing the OS?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
It sound like firmware/NAND issues.
It would be very difficult to fix this.
I would check with Meta their support to see what options you have.
Anyway, if you would like to know more about it's NAND, you can follow this: Meta Quest 3 Chip-ID
Hopefully Meta does have a solution for you or maybe you can sent it in, so that they can refurb it.
Sorry for the bad news.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Aleksandr Muchin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 18
Altijd: 62
