Ga door naar hoofdinhoud
Een spelcomputer voor in de hand, gemaakt door Valve en uitgebracht op 25 februari 2022.
Having Troubles with Steam Deck Update
Ever since their was an update. my steam deck buttons, L2, Steam button and three dot button stop working if there is someone who can help please let me know
Mise à jour (08/04/26)
I also tested on the controller testing thing in the settings too test device. is there anybody out there come and help me? because i live in Perry, Ny. and got no car take me to get it fixed
Is dit een goede vraag?
4 opmerkingen
@kristoferu90180 We don't really give in-person repairs, here. And please do not give out your location, that is a doxxing hazard if you do so.
Either way, what else have you tried?
door
Okay my bad it’s my first time trying this website. I try shutting off my steam deck completely and let rest awhile because this not first time it has happened to me
door
@kristoferu90180 No worries! I think that someone had the same or at least a similar problem that you have with this particular device.
door
If there’s anything I can do make it work again please let me know. Unfortunately I don’t got any tools to take apart and see the issue is if comes worse terms might someone check it out or can wait till tell me I can do
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Is the issue constantly? Or does this only happen for a short time right after a update? It sound more like firmware related to me...
Try to recover it and see if that works: https://www.reddit.com/r/SteamDeck/comme...
If that doesn't work, you might need to replace the motherboard...
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I did the Factory Reset and still giving me issues personally I think Steam needs do another update for Steam Deck users because this not first time like I said previously…
door
Just curious do I need to Clear user data and configuration? Or just leave that alone?
door
Never mind I did full restart and sadly still giving me same issues again I’m wait till Steam updates it so be easier for Steam Deck users
door
Clear and format everything (make sure you got backups). If it's still failing even after that, you could wait for another update but this should not be normal behavior. Maybe it's for the best to contact Steam Support? Maybe they have some tip and tricks as well!
door
Voeg je antwoord toe
Kristofer Urquidi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 61
Afgelopen 30 dagen: 61
Altijd: 61
