Ga door naar hoofdinhoud
Ook verkocht onder de namen GMC Sierra en VIA Vtrux, verkrijgbaar in de VS, Canada, Mexico en andere landen over de hele wereld.
My reverse light are always on
My 05 chevy 1500 has a flatbed on it and was done on amature hour. The rear end wiring wasnt working so I decided to run new wiring from the fuse box using a fuse tap all the lights work but the problem is my reverse lights are always on. My question is does the switch for the reverse lights that i assum is either on the shifter or transmission lie between the battery and fuse box or the fusebox and the lights. If it's the latter then obviously I bypassed the switch but none of the other lights are like that so I don't see that being the case
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @loganloren71558
The backup switch is between the output side of the fuse and the BCM (Body Control Module) i.e. battery → B/UP 20A fuse → backup switch → BCM → backup lights.
Here's the backup lamp wiring diagram from the service manual.
When reverse gear is selected (either AT or MT) B/UP 20A fuse supplies voltage via the operated backup switch, to the BCM. The BCM then supplies the voltage to operate the backup lamps.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Chevylodge89 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 57
