Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Nikon D90 is een 12,3 MP DSLR-camera die zowel foto's als video's kan maken.
The shutter is stuck.
The shutter is stuck. It's partially open and I can't move it. An "ERR" message appears. Does anyone know how to fix this?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
@leonardobue7263 the "ERR" message on a Nikon D90 is a general hardware failure warning and really does not identify a particular error. SInce it pops up with your shutter being stuck it could signify that there is a mechanical jam in either the shutter curtain or the mirror charge mechanism. Download the SM from this age Nikon D90 under the Documents header.
First thing you want to do is remove your lens and inspect the shutter blades. Look at the mirror inside the housing. If the mirror is stuck in the "up" position, look directly at the shutter curtain behind it. If those metal shutter blades are bent, misaligned, or popped out of their guide tracks, your shutter assembly is damaged and will need to be replaced. Just remember, do not touch them if they look perfectly flat and aligned.
Next, you will want to check the aperture control lever. Look just inside the left side of the metal lens mount ring. You will see a small metal lever that slides up and down to control the lens aperture. If this lever gets bent and binds against the housing, it will freeze the entire mechanical sequence and throw that ERR code.
If the shutter blades look okay and the mirror is just stuck halfway, the sequence motor itself might be jammed. Check in the SM around page 69 and others. Remove the bottom plastic cover of the camera body. This exposes the bottom of the motor gearbox. You can use a small pick or a precision flathead screwdriver to manually rotate the main sequence gear a few teeth to try and free it up.
Was dit antwoord nuttig?
Score 1
I encountered a similar issue and resolved it by replacing the motor's pinion gear, following the instructions in the service manual.
It appears that this problem can also be caused by a disconnected electrode on the position sensor or a mechanical jam; in such cases, disassembly and repair will likely be required.
I have uploaded a guide that I hope you will find helpful.
Nikon D90 rondsels van de oplaadmotor vervangen..
Voeg je antwoord toe
Leonardo Bueno - Oficial zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 74
Afgelopen 30 dagen: 311
Altijd: 782
