Ga door naar hoofdinhoud
iPod water damage?
I went swimming in a pond for about fifteen minutes when I realized my iPod was in my poccet. what can I do to fix it. will that much exposure make a difference? HELP!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Rebecca, yes it does. No matter how long it was in the water, it may still have water damage. The first thing you do want to NOT do is to turn it on. You will have to remove the battery, and clean the iPod. Use these guides to disassemble your iPod. then clean it using this guide. It was written for a #G iPhone but all the points are still valid. Once cleaned, re-assemble your iPod and re-evaluate for any damage. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rebecca zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 485
