Ga door naar hoofdinhoud
De Samsung Galaxy A23 werd uitgebracht op 6 maart 2022. Het toestel is te herkennen aan het modelnummer SM-A235F.
Phone exposed to rain; screen shows lines and operates abnormally.
My phone exposed to rain, when i woke up in the morning and turn the screen on after few seconds first i saw white lines and it get whitish background and phone operate itself abnormally. what could be the solution of this.?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi @durgeshsingh
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a guide that may help as it shows how to open the phone so that you can get access to the systemboard etc.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Was dit antwoord nuttig?
Score 1
Right here's what you need to do
Step 1. Get device
Step 2. Walk out door
Step 3. Get in vehicle
Step 4. Start vehicle
Step 5. Go to local authorised repair shop
Step 6. Explain issue to service representative
Step 7. hand device over and pay
Voeg je antwoord toe
Durgesh Singh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 39
