Ga door naar hoofdinhoud
Screen has vertical lines
I just bought a 60" Samsung TV (model UN60JS8000F) off Facebook Marketplace. The seller said it was working perfectly fine until they had a lightning storm one night. After that, some vertical lines appeared in the display.
https://ibb.co/hJxVTT4P
He said the area in which he lives is notorious for power surges. As the TV still has power and sound, I suspect the TCON board took a hit. I've been watching a lot of YouTube TV repair videos lately and several times I've seen people "work around" the issue by putting tape over some of the pinouts on the TCON's ribbon cable.
Before I try anything else I'm going to try power resetting the TV and also a factory reset. However, if neither of these steps solve the issue I'd like to try the tape method. Is there any way to definitively identify which pinouts are malfunctioning (if that is indeed where the fault lies)? More often than not, it seems like the techs just used trial and error.
Also, if anyone with this particular model has experienced the same issue and can provide some advice/insight as to what I can try to fix the issue that would be greatly appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@bodrey the Tape-off will not work if your T-con board or main board have failed. A tape-off will not restore your T-con function.
Looking at your image, this will not be a T-con board issue. That is an issue with your Source Driver CoF that attach the buffer boards to the LCD panel. Remove the back cover and locate the buffer boards. Take a couple of well focused images of where those boards connect to the LCD via a "film" (plastic feeling) ribbon cable. Let's see if there is any visible damage.
Was dit antwoord nuttig?
2 opmerkingen:
Hi OT,
OK, thanks for the quick response and assistance. It could be a few days before I'm able to follow up with you. I'm in the process of renovating my house right now. So, the place is in a state of disarray at the moment.
door
@bodrey take your time. we all know how life happens :-) WE'll most likely be here whenever you are ready.
door
Voeg je antwoord toe
Bodrey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 33
Altijd: 33
