Ga door naar hoofdinhoud
Reparatiehandleiding voor de Dell Optiplex 790
Why power button blink orange light
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @abdulhadi96018
Check which diagnostic LED lights 1-4 on the back of the computer are on as they will tell you what the problem is.
Go to p.73→p.75 in the owner manual to see all the combinations and what to do.
Was dit antwoord nuttig?
Score 2
An orange light typically indicates a power delivery issue or an internal hardware failure preventing the system from starting. Unplug everything (including the power cable) from the computer and press and hold the power button for around 20 seconds until the pc drains of power. Then, plug only the power cable in and see if that fixes it. If it doesn't, then you can try to see if your PSU is the issue. Locate the small button and LED light next to the power cord inlet on the back of the computer. Press the button. If the LED is solid green, your power supply is perfectly fine. If it remains unlit, or it blinks, your PSU is at fault, and you should replace it.
1 Opmerking:
PSU is perfect but still orange light
door
Voeg je antwoord toe
Abdulhadi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 71
Altijd: 428
