Stick drift and trigger issue
Afbeelding
help my joystick aint stick drifting its more like Tokyo drifting, I have attached media of one.
my main controller had trigger issues which was giving a response when I wasn't even using the triggers so I used the same conductive film but switched the hardware of my other controller's pcb board which wasnt turning on and then the trigger issue was resolved but the that Tokyo drift issue came up so I guess the board is the issue but I'm not sure
Is dit een goede vraag?
1 Opmerking:
Hi!
Could be the board, could be sticks.
Did you tried to replace the joysticks?
Can you share a picture with us regarding the board?
Thanks!
door Deel
Voeg een opmerking toe
