Ga door naar hoofdinhoud
How to take apart and repair the Panasonic Lumix DMC-FX01.
12 Vragen Bekijk alle
Black point when take picture
Hi all,
My Panasonic Lumix is an excellent material for what i do. no need of extra things. It suits me perfectly.
But, actually it give me some bad results.
For any know reason, some picture i take have a black point on it. the black point seems to appear in some particular situation, like a little zoom or with a more longuer autofocus time.
This give to me some pictures with a black point.
Do you know from which part of the material could be in cause ?
Is it Lens ?
Thanks in advance for any answer you can give me to help.
Best Regards.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Julien, both of your questions point to a bad or dirty lens. You can try to clean the lens or to replace the lens assembly. Of course you also want to make sure that your flex cables are properly seated, and free of any corrosion. Here is the guide for the lens replacement. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Julien zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 712
