Inleiding
If your Panasonic Lumix DMC-FX01 is unable to take pictures with the lens or the lens refuses to open, this guide will show you how to replace it. A camera lens is an important component to a digital camera. Without it, the image you want to capture will not be possible.
Smaller digital cameras like this one come with very small pieces that you will need to remove. As you will see later in the guide, it is important to be a delicate as possible with the pieces to ensure you do not cause any more damage to the broken item.
Before you begin, check the battery connecter to see if any debris is preventing the battery to make the lens work (this is a common reason the lens will not work).
Once you have confirmed that the lens is not working, begin this guide.
Wat je nodig hebt
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
4 andere personen hebben deze handleiding voltooid.
