Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Realme 9 is een mid-range smartphone ontworpen door Realme, uitgebracht in 2022.
My phone not speaker
Mere phone me avaj nahi sunai deti hai
Update (04/14/26)
  1. Mere phone avaj nahi sunai deti hai
Is dit een goede vraag?
Score 1
4 opmerkingen:
Power button dabane me nhi khulta
door Deel
Display remove in phone
door Deel
Mere ka mic kaam nhi karta
door Deel
Speaker mein awaaz bahut kam aata Hai
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
@princekuma96001 @rohitkewat no sound or low speaker volume is usually caused by clogged mesh, an audio setting, or a failed speaker module. Since no one mentioned which speaker is low volume or not working, you have to determine if it is the earpiece speaker or the speakerphone one. Make a call and toggle the toggle Speaker on and off. If the call is quiet against your ear but loud on speakerphone, the top earpiece is the problem. If music, ringtones, and speakerphone are all quiet, focus on the bottom loudspeaker.
Also clean the speaker mesh with a clean, dry, soft-bristled brush. Do not poke anything into the mesh holes as you could damage the speaker.
Next make sure that this is not a setting issue. Turn off Bluetooth to make sure the audio does not accidently gets routed to any previously used earbuds or speakers etc. Next go to Settings ==> System/Additional Settings ==> Accessibility ==> Hearing and make sure the Audio balance slider sits in the middle. Then open Settings ==> Sound & vibration and raise Media, Ring, and Call volumes separately. Now play a video or audio and see if that made a difference.
If not then you know the issue is not a settings issue but it is hardware related. You will have to replace the speaker module. Since iFixit does not yet have a specific guide for this, use something like this video The bottom speaker is shown at 4:22min and you can see the earpiece speaker in the last minute after removing the main board. It is the part in the top center position.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Voeg je antwoord toe
Prince Kumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 47
Altijd: 443
