Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de derde generatie Sony PlayStation 5 DualSense-controller. Te herkennen aan modelnummer CFI-ZCT1W en moederbordmodel BDM-030.
Faceplate Compatibility with other versions
Hi, I own a V3 Controller and it is the Spider-man 2 variant controller. It has developed stick drift and I am hoping to avoid having to solder anything.
Can I transfer the face plate and track pad plate onto a V5 controller?
If not, will the motherboard and sticks from a V5 fit and connect with internals from a V3?
For reference i have the motherboard serial number BDM-030. Any help is appreciated I would love to keep the livery on this controller if joystick replacement is the only option then that'll have to do. Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Yes that is possible, but you do need the EXACT same model. Also the motherboard must match with each other.
It could be a little difficult, if you buy a incorrect model it just won’t fit as it should be.
Also another option would be to bring to a local repair shop and ask them to solder new hall effect sticks in.
Please let me know how it goes :)
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hi! Apologies for the late response I just attempted it, and it did indeed work. I bought a brand new dual sense and was able to transfer all of the internal components apart from the touchpad which I wanted to retain and the new battery housing. All the internals from a new controller bolt up perfectly. I wanted to reuse the touchpad and faceplate so I did. Due to small changes in architecture I had to also reuse the old battery housing, rear plate and trim piece.
door
No problem at all! Glad that you got it solved :)! Thanks for sharing this with us! Have a great day!
door
Voeg je antwoord toe
Thorne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 119
