Dryer is not working
When I start the dryer, it makes a click sound and does not start. How can I fix it? The lights are not and the power is connected.
Is dit een goede vraag?
Here's the tech sheet for the dryer.
Run the diagnostic tests as described on p.1 and check what error code is displayed.
If the diagnostic tests don't work, see the Troubleshooting guide on p.4.
If you find a faulty part and it needs replacing, due to the age of the dryer a lot of the part numbers shown for the parts in the tech sheet on p.2 are no longer valid. Here's a current parts list that may help.
Locate the wanted part in the list and note the replacement part number shown for the part. Search online for the replacement part number only to find suppliers that suit you best.
Was dit antwoord nuttig?
I ran the diagnostic test and all lights were on (red) only the dryer light was green. No lights were flashing. pressing each button had a beep tone. I pressed the start button and two-digit display indicated "06" not "01".
Did you try the troubleshooting steps on p.4 in the tech sheet as suggested above, you never said?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 30
Altijd: 200
2 opmerkingen
What is the model number of your washer? It's important for us to know that in order to look up the correct troubleshooting information.
door Jerry Wheeler Deel
110.82826102
door Mujiburrahman Khateer Deel
