Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de Kobo Libra Colour eReader van Rakuten Kobo, uitgebracht in april 2024. Te herkennen aan modelnummers N428 of N428B.
Is it a software or hardware issue? Image attached
Hello! When I took my eBook out of its case, the screen looked like this. It has been exactly one year and one week since I bought the device, so it’s no longer under warranty.
I need help to know whether you think the screen is broken and I should buy a replacement and repair it, or if it could be a software issue.
I haven’t dropped it or hit it, but it was inside my backpack.
Thank you very much!
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
yes that is a broken display, it would need to be replaced.
Was dit antwoord nuttig?
2 opmerkingen:
Thanks a lot! wish me luck replacing the screen by myself hahaha
door
@isdt good luck! use heat and 99% isopropyl alcohol (in small bits), it may help loosen the adhesive.
just make sure to check and see if the displays come as a digitizer with the display, or separately. some devices are laminated together and you cant just replace one or the other and both need to be replaced as one piece.
door
Hi @isdt
The screen is broken and will need to be replaced.
Depending on which model you have here are the ifixit Kobo Libra Colour (N428) Vervanging van het scherm and the Kobo Libra Colour (N428B) Vervanging van het scherm guides that will help.
If you have the N428 variant, then ifixit have the screen assembly in stock but not for the N428B version it seems.
Kobo Libra Colour N428 Scherm Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
45 minutes - 1 hour
Kobo Libra Colour N428B Scherm Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
Voeg je antwoord toe
ISDT zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 20
Altijd: 183
