Ga door naar hoofdinhoud
Grotere versie van de Nintendo DSi, uitgebracht in maart 2010 in Noord-Amerika. De meeste reparaties kunnen worden uitgevoerd met alleen een schroevendraaier en wrikwerktuigen.
Touch screen bezel coming off
Hi guys,
Lately I was having some problems with my DSI XL's touch screen "pulling" to the left of the screen when touching. I inspected the screen and I noticed the border / frame / bezel around the screen has come loose a bit from the adhesive that attaches it to the touch screen. I cleaned it from any dust and debris but it won't attach properly to the screen anymore.
How would I have a go at repairing this properly?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
First of all, without the border, does it work?
If not, I would replace the touchscreen completely for a new one.
Guide: Nintendo DSi XL touch screen vervangen
I would also get a new border from AliExpress. They are cheap and will stay on there.
Replacing is the best way to get it fixed, I'm afraid.
Please let us know how it goes!
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Hi Koppie,
Thanks for your quick reply. Yes after cleaning under the border it works again but I would like to prevent dust and debris from accumulating under the border! I've searched online for a replacement but not sure what search query I should use. Is it called a touchscreen border? How would you go about removing and cleaning it properly if you don't mind me asking?
door
Okay that is good news!
You mean this > https://www.aliexpress.us/item/325680649... ?
You can get the "plastic color bezel" off it, I think (not sure).
Otherwise, if you buy a new shell, you will get it there as well. But then you need the exact same color as you are having now.
door
I'll always leave the touchscreen and the bezel there and clean it from the outside, if that doesn't work, I need to take off the bezel carefully and put it on there, if this failed, I need to replace it..
door
Voeg je antwoord toe
Teqhniq zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 140
