Ga door naar hoofdinhoud
De New Nintendo 2DS XL is op 28 juli 2017 uitgebracht en is een technologisch verbeterd model van de 2DS-handheld. Het is het negende en laatste herontwerp van de Nintendo DS-lijn. De console is veel groter dan het originele 2DS-model en bevat alle functies van de bijgewerkte 'New 3DS'-lijn, minus de mogelijkheid om games in stereoscopische 3D op het bovenste scherm te spelen.
Charging light but power button does nothing
Hi
I have a 2ds XL that won't turn on, it charges fine and I have tried a known working battery with no luck, the blue light never comes on, I have checked the 2 fuses and they have continuity, I did check for vaultage on the power button but it doesn't seem to be getting any power when pressed, but it gets continuity, wondering where and how I should test from here
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
You have tested a lot already. Since the battery and fuses are OK, it would be difficult to find where the fault is.
Must be somewhere in the power area near the battery. The power button should work when it gives continuity.
How are the battery pins? Still good? No corrosion?
It could be a lot of things. I think it's easier (I know, it's more expensive..) to get a new motherboard.
Guide: New Nintendo 2DS XL moederbord vervangen
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Well it's more of a want to learn more than a need to fix it lol, guess I just need to learn to follow traces and check where the vaultage stops at this point
door
I would check near the battery, that location!
You can find some more info here: https://gbatemp.net/threads/n2ds-xl-wont...
door
Voeg je antwoord toe
Yelo Hill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 237
