Ga door naar hoofdinhoud
Dit is de pagina met reparatiehandleidingen en Probleemoplossing voor de Sony PS2 Slimline (SCPH-750xx). Het Sony PlayStation 2 Slimline-computersysteem is een kleine, slanke en netwerkgereed spelconsole.
Optical Drive not working.
Heyy,
I had a PS2 Slim (Pink Version) SCPH-77004 with a broken shell (the rest was completely fine)
To replace the shell I ordered a defective and labeled as "Don't Reads Discs)"(Same Type, Same model of course) (might be a different MB Version, didn't checked)
The spare wasn't opened before. Like described it booted and was behaving normal in home screen, it didn't read a disc, but furthermore it didn't seem to even show life of the Laser Assembly (no Motor Spinning, no Laser movement)
That's when I started disassembly, first I checked/tested the two lid switches, both pressed, same result. Both tested good with a multimeter
I tried the working Assembly from my own Slim, and had the same result. The rail tested in my Slim showed Laser Movement and the motor was spinning up. (Didn't read discs, made clicking noises)
I did the same thing with the ribbon cable (so using the ribbon vice versa on both machines) which also provided the same results, I inspected the board of the Spare one and didn't saw any (obvious) issues. And I also checked the Ribbon connectors for lose (cold) connections.
The Spare also didn't looked dirty inside at all, it was like opening a never used console.
So in short:
Laser Assembly good
Ribbon cable good
Ribbon cable connectors good
No obvious MB issue (with Eyes)
Lid switches fine
My question now is, what could it be? Where could/should I start looking for an issue? Did anyone had a similar problem?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Best thing is to follow this video: https://www.youtube.com/watch?v=Pthhet1_...
It can be way more then the laser and the lid switches (good thing you've checked those, as when they are faulty nothing is moving at all).
I would check your symptoms and see what issue it's having. I think it's something on the motherboard that died...
Can you let us know how it goes?
Thanks!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
TheToptic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 96
