Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de derde generatie Sony PlayStation 5 DualSense-controller. Te herkennen aan modelnummer CFI-ZCT1W en moederbordmodel BDM-030.
Adaptive Trigger Auto Trigger
I was just finished installing the Hall effect on the controller, and they work fine. However, the trigger motor for adaptive triggers on R2 activates on its own. I disconnected the flex cable, but it still triggers. It doesn't seem to be the springs or anything as the triggers work and they retract, just that the triggers just activate to like a resisting gun trigger every 4-ish seconds. Its seems to be software-related. An y Fixes other than disconnecting the wires?
Is dit een goede vraag?
4 opmerkingen:
Hi!
What does gamepad tester says? Also that it's pressed in? Is the firmware up to date? How are the traces? Are none of them are damaged during soldering?
Thanks!
door Deel
The traces are fine now the auto clicking stopped but when I use the https://ds.daidr.me/ Dualsense Tester the Triggers only go into resistance. The auto trigger mode does the same thing as resistance. The Only trace that was accidently torn isnt even related to that. Im fine without the adaptive triggers but my mute button doesnt work
door Deel
gamepad tester says normal, btw
Its not pressing in on its own, its just the adaptive triggers. Firmware is latest
door Deel
Hmm, can you share some pictures with us regarding the motherboard and it's traces? Then we can take a look at it! Hopefully that is OK :)!
Thanks!
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Check button for firmware reset.
Was dit antwoord nuttig?
Voeg je antwoord toe
Elvin Eve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 45
Altijd: 297
