Ga door naar hoofdinhoud
De PlayStation 3 Slim is de tweede versie van de PS3-spelconsole met het oorspronkelijke modelnummer CECH-2000. Geproduceerd door Sony Computer Entertainment, loste het veel problemen op van de originele (fat) PlayStation 3. Het werd uitgebracht op 1 september 2009.
retrieving data from a ps3 hard drive
how do i retrieve the data from a ps3 slim hard drive as i have movies videos and other personal files and folders on the drive but unable to retrieve them so how do i do this as i want the drive contents off if a full memory wipe is to be performed
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi!
You cannot connect it to your PC and read the data from the HDD. This is because the data is encrypted with a unique key.
If the PS3 is still stock, the options are very limited and the chance is small that you can transfer it to your PC or NAS (it only can play from the NAS).
What kind of video's do you mean? Home videos? Downloaded movies from the PS Store? If the PS3 is still working, you can try to transfer them with a USB.
Plug the USB drive into the PS3 and go to Video > Highlight the video file > Press triangle and go to copy, copy it to your USB drive.
Be aware: Only FAT32 formatted USB drives will work, so the file size is limited to 4GB.
And what do you mean with personal files..?
There are not that many options left, I'm afraid.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
does not matter what type of files they are just need to retrieve them
door
The only thing you can try is to plug in a formatted FAT32 USB drive. Go to the files and movies, press triangle and search for the copy option. Copy it to your USB drive. That is the only way if your PS3 is stock.
door
@dan0 I am unable to access the ps home as I utilised the drive using windows 11
door
If the drive is utilized it’s impossible to retrieve the data… sorry for thr bad news :(
door
Take it apart and connect to a PC using a SATA/SAS to USB cable.
Retrieve the files using your file explorer and then reconnect to your PS3
4 opmerkingen:
I don't think it works that way. The PS3 drive is encrypted with a unique key. You cannot just read the data on a computer.
door
I already tried that and nothing so that is bull
door
I completely forgot about that thanks guys!
Use this: https://github.com/jhonathanc/PS3-HDD-Re... make sure to follow the instructions. Good luck!
also use https://www.psx-place.com/threads/dumpin... for the root key
door
No problem at all! We are trying to help in any way :).
door
Voeg je antwoord toe
Matt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 72
Altijd: 429
