Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Microsoft USB Force Feedback joystick-gamecontroller. Augustus 1998 X05-92622
Auto Center Weak in One Direction
Recently picked one of these up used (only way to get them today, obviously), and the auto-centering function seems to work very weakly when I pushed the joystick forward, or not at all. I'm assuming there is some mechanism inside that needs to be cleaned/fixed/replaced. Has anyone done a teardown of this base, or repaired the Auto Centering/FFB mechanisms inside? I'm assuming most of the parts inside could be ordered and/or 3D printed, but I don't know where to start.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
@dantehchad take a look at this teardown You may have some bad pots that may need to be replaced as well as cleaning the gears, motors, etc. Also, try the ForceTest.exe from here or the one from here, and see if you can configure your joystick to give you a better auto center feel.
While you work on your Joystick, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Voeg je antwoord toe
Dan teh Chad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 37
Altijd: 260
