Install new RAM problem
Is dit een goede vraag?
@eijuvp6xzseev2s the RAM module in your picture is a DDR4 2400MHz RAM module. Your HP ZBook Fury 15 G8 system standard for RAM is 3200MHz. Using the memory module shown in your image, will significant slow down your computer. I would strongly advice against using it. Consider it incompatible. ¯\_(ツ)_/¯
Was dit antwoord nuttig?
Hi, would you mind explaining what problem you're experiencing?
- Is it that the ram does not fit?
- Does the laptop not boot with the ram?
- Is the ram stick broken?
If you need instructions, you can follow this guide for you laptop HP ZBook Fury 15 G8: Warmtewerende lijm vervangen until Step 3, were the ram will be accessible.
Thanks, may it cause blue screen problems, so I removed it.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 47
Altijd: 347
