How fix boot error in probook 4530s modle
How to fix boot error in probook 4530s
Is dit een goede vraag?
A boot error on an HP ProBook 4530s usually comes from incorrect BIOS settings, a failing drive, or corrupted boot files. First, enter BIOS (press F10 on startup) and ensure the hard drive is detected and set as the first boot device. If detected, run HP Diagnostics (F2) to check HDD health. If the drive fails tests, replace it. If the drive passes, boot from a Windows installation USB, choose Repair your PC, then run Startup Repair. You can also use Command Prompt to run bootrec /fixmbr, /fixboot, and /rebuildbcd. Update BIOS if needed. If errors persist, reinstall Windows.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 134
1 Opmerking
Hi! Do you get an error code..? Where does it goes wrong? In Windows or in the POST? Do you get a diagnostic screen from Windows? Can you share some pictures with us? Thank you!
door koppie007
