Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
key button not working
Few buttons not working
Update (11/23/25)
Afbeelding
Is dit een goede vraag?
Score 1
3 opmerkingen
Hi @fzengo
What is the model number of the microwave oven?
Which buttons aren't working?
door Deel
Model # MS14K6000AS
door Deel
Currently now all buttons are not working
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @fzengo
Sounds like there's a problem with the control panel assembly.
You could try opening the oven and removing the control panel and then check if you can open the panel to see what's wrong.
Alternatively search online for a replacement control panel. Search for DE94-03322M to find suppliers that suit you best. (examples only). This is the part number for the control panel in the oven
Be safety aware when working inside microwave ovens. The HV capacitor in the oven can store >5000V DC for months, even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the oven's cover has been removed and before commencing any further work inside the oven. If you don't know what you're doing, then don't do it! Contact an appliance repair service and ask for a quote.
Replacement assembly control panel for your Samsung 1.4 cu. ft. microwave. Afbeelding
Product
DE94-03322M - Samsung Microwave Assembly Control Panel
$166.99
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
fzengo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 111
Altijd: 719
