Need schematic, Cannot find. Code F28
Hello. I need the schematic for a HE2plus Kenmore, model 110.47511701 . I have exhausted my search.
I am getting a code F28 after changing the door latch, the control panel and the inlet switch.
This machine will not start filling.
The drain pump was also replaced recently and worked fine.
The machine was reset numerous times and connections checked. The only thing left is to put a meter on it.
Any help will be appreciated. Thank you.
Is dit een goede vraag?
3 opmerkingen
Have you checked inside the machine for service sheets that are often stored there for technicians to use?
door Jerry Wheeler Deel
Yes, it is missing.
door RJ Traub Deel
This model is made by Whirlpool.
door RJ Traub Deel
