Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
battery and thermal sensor
Hello - I was about to order a battery replacement kit and some tools - then I spotted the question about thermal sensors - I read the query and it described my 3GS symptoms exactly - the answer you gave was no it wasn't included - but no mention of how to order the thermal sensor or replace it. Please can you advise if this is an item you can supply for replacement.
Thanks Phil (UK)
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Phil, most of us on here are not directly connected to ifixit. We are common users that like to assist others with the repair of their devices. If you need to find out if ifixit supplies certain parts, contact them on here http://www.ifixit.com/Info/contact Good Luck
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Phil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 267
