Ga door naar hoofdinhoud
Bekend als de ''PS2'', is het een zesde-generatie spelconsole die in maart 2000 voor het eerst door Sony in Japan werd uitgebracht. De Verenigde Staten zagen het apparaat later in 2000 met de SCPH-30000. Reparatie van dit apparaat vereist alleen gangbaar gereedschap, maar kan lastig zijn.
Fat Ps2 Scratching discs?
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Typically when discussing Ps2's that scratch discs, the slim is the first thing that comes to mind. I have however recently purchased an SCPH 50001/N model and noticed that mine is scratching discs a bit differently. After having searched many forums, I can not find so much information.
Here's the issue:
I have purchased games recently that were very clean (SCIII and SOE) and decided to pop them into the PS2. What I've noticed is that after 30 mins or so I receive a pattern of hair like circular scratches around the disc. Now keep in mind, these are not circles that ring around the whole disc, rather its a pattern of multiple circles around the disc. What could be causing this? If you need pictures I am able to upload but any help would be appreciated as I can't find anything.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Could be multiple things.
1: The laser is replaced and not correctly installed (in height).
2: The top case has been replaced with another one, but is the incorrect type/version.
3: Disc drive isn't alligned properly (less likely).
4: Something is stuck inside the disc drive causing scratches.
Did you recently repaired the PS2? Or did the previous owner?
Replacing the disc drive is a option, replacing the top case is difficult as there are many versions out there.
If you can share some pictures, that would be great!
Was dit antwoord nuttig?
Score 1
6 opmerkingen:
Hi there! Thank you for engaging with my post. I have just posted the pictures now. Let me know if you have any questions.
door
Hi!
Yes, I would replace the top cover of the disk drive. There are 2 main versions out there.
1: Top loader with 2 clips and 2 screws.
2: Top loader with 4 screws without clips.
You need the 1st one. The one with 2 clips and 2 screws. I would replace that one and see how that goes. If the same issue occurs, I would replace the laser and check afterwards.
Still facing issues? Then you most likely want to replace the whole drive.
Please let us know how it goes!
door
@dan0 Thank You. Just out of curiosity, do you see any issues with the top loader itself which causes you to suggest that?
door
My pleasure! No I don't. It's hard to see with the eye. I know from experience that the top loader is usually the culprit..
door
@dan0 Ok! I really appreciate your help!
door
1 commentaar meer tonen
Voeg je antwoord toe
Tom19 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 50
Altijd: 812
