Ga door naar hoofdinhoud
Reparatie- en probleemoplossingsinformatie voor het FixHub Power Series | Mobiele Soldeerstation, de combinatie van het mobiele soldeerstation en de slimme soldeerbout. Gelanceerd in oktober 2024.
Idle mode during soldering
  • Firmware 1.4.2, iron solder enters into idle mode during soldering. idle mode is configured with 20 seconds large enough normally. I don't do a lot of movements when I solder but it seems that it's not enough.
  • Is there a way to have the iron solder more sensible? Else I can turn off idle mode and just power off the iron.
Is dit een goede vraag?
Score 1
1 Opmerking:
I’ve forwarded you question to the iFixit team, hang tight!
door
Voeg een opmerking toe
1 Antwoord
@jonathanra66195 , You’re right, the motion sensor can sometimes go idle a bit too quickly during steady or delicate soldering work. Unfortunately, there isn’t currently a way to make the motion detection more sensitive.
The easiest workaround is to turn off Idle Mode entirely so the iron stays on until you power it down manually. Here’s how to do that:
  1. On the iron, open the Settings menu.
  2. Scroll down to Idle Enable.
  3. Toggle it Off.
  4. Optionally, set your Sleep Timer or Auto Power Off for safety.
That’ll keep the iron active the whole time you’re working. Just remember to switch it off when you’re done — disabling Idle Mode means it’ll keep drawing power and can shorten tip life a little over time.
Let me know if this helps or if you have any other questions.
Was dit antwoord nuttig?
Voeg je antwoord toe
jonathan ramos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 207
