Ga door naar hoofdinhoud
Reparatiehandleidingen voor verschillende soorten geheugen en opslag, gaande van interne harde schijven tot netwerkgeheugen.
How to remove heatsink Samsung 9100 SSD
I bought the Samsung 9100 Pro with heat spreader/heatsink (low profile) thinking it should fit, if not I could remove.
Samsung used what might be star screws because T5 Torx doesn't work and T6 is too large.
Can someone confirm type and size of the bit I need?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@tumanwk we have to see what the screws look like. there are to many aftermarket suppliers and we do not know what this particluar one may have use. Voeg afbeeldingen toe aan een bestaande vraag
The ones I have seen were P5 (Pentalobe) screws
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks for the quick response.
You guessed correctly it's pentalobe, I have to find where I miss placed my iFixIt Pro Tech Kit... Just verified the P2, P5, and P6 should be in my kit online. Now I just need to remember that wonderful location I moved it to, in order for it to be easier to find when needed.
My other kits are older and do not contain this bit style. I think unofficially when Apple started using these screws people referred to them as star bits .. but that didn't work, I figured best to ask the experts here.
Besides the training classes for Apple, (did phone technical support CPU/Computers) I haven't had to use Pentalobe screw bits/driver.
door
Voeg je antwoord toe
Tuman WK zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 75
Afgelopen 30 dagen: 424
Altijd: 855
