Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Informatie over reparatie en demontage van de vierde generatie Fitbit Versa smartwatch. Uitgebracht in september 2022 en herkenbaar aan modelnummer FB523.
Side button not working
The button on the side of the Fitbit does not work. You can press it but it doesn’t do anything. The rest of the Fitbit works fine so would be a shame to have to get a new one
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
It could be that the soldering points are no longer making the button have contact with the motherboard
Was dit antwoord nuttig?
Managed to get our Fitbit Versa 4 working by lightly tapping the button and surrounding area with a small screwdriver handle!
The Issue: The watch only woke up when plugged into USB, showing the setup screen (history unknown). The button was totally dead—it wouldn't register clicks, wake the screen, or progress past setup.
The Fix: The button felt fine physically (not mushy, nice click), so mechanical failure seemed unlikely. Hoping to clear potential moisture buildup or a stuck contact, I gave it some mild vibration treatment. Why exactly it worked is still a mystery, but the tapping did the trick and brought the button back to life.
Voeg je antwoord toe
Rosa Ross zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 120
Altijd: 453
