Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Informatie over reparatie en demontage van de tweede generatie iPhone SE, aangekondigd en uitgebracht in april 2020.
Battery dies super quick
It dies so quickly
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Could you elaborate more? As far as I can tell you just need to replace the battery
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Oh no the battery compadity is literally 79 %
door Deel
@thecat847 Yeah that is way too low. At 85 you should replace it
door Deel
It works but I do have a toolbox to take out screws but no way to soften the glue and no replacement battery
door Deel
Go into your Settings under the battery heading will be the battery health. It's a percentage from 0-100 showing what the current capacity of the battery is vs. how much it should be able to hold. If it's less than about 85%, Apple says it should be replaced.
Over time batteries lose the ability to hold a full charge, so even though it says it's charged to 100%, it may only be holding 2/3rds as much charge as it should, meaning it's going to die in a much shorter time than it used to.
The solution here is to replace the battery. iFixit has a guide showing you step by step how to do that yourself. Note that unless you buy a genuine Apple battery (and have iOS 18 or later), you'll lose the ability to view the battery health information and get a pop-up warning for a week or so that the phone cannot determine if the battery is a genuine apple part. Other than those issues, an aftermarket battery will charge and work normally.
iPhone SE 2020 Battery Replacement - iFixit Repair Guide
Score 1
Voeg je antwoord toe
The cat15 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 207
