stop lights not working
I have no stop lights check break light switch good it's blowing fuses
Is dit een goede vraag?
@stevepucke73877 if it blows the fuses when you apply the brakes you have a short circuit. This will be either along the wiring harness or in the bulb socket. You will have to check by using a multimeter in ohm mode. If you are unfamiliar with this check something like this video and I would start on the light socket itself.
Here is the wiring diagram for the '99 S10 but it should work for the Xtreme as well
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 166
