Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Ergonomische Logitech Lift-muis. Verkrijgbaar in zwart, wit en roze.
Left click button does work inappropriately,
Hi
I had used it around 10hrs every weekdays over two years, it is quite a long time use for daily basis because I am full time a drafter and designer. It started not reacting often with the left click button. yeah sometimes work sometimes not.
I've just replaced it with another new lift but if I can fix it, would glad.
Is dit een goede vraag?
Score 2
2 opmerkingen
same for me. its a pity, i will reorder new one, but itl sure happen again. i didnt use it that much. but it happened after 2 years too
door Deel
Right button is glitching for me. Purchased Aug 22.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
@hyundongsung check your mouse and see if this is a mechanical or electrical issue. Use something like this teardown Logitech Lift Demontage to work on it. Check the plastic parts, the ribbon cable as well as the switch board. Let us know if you find anything that looks odd. Sometimes the top of the switches get wore down and the button does not reach deep enough to activate the switch. Adding a small piece of felt to the top of a switch can restore that function. If not, simply check the switches for function with a multimeter and see if they close the circuit when activated.
Was dit antwoord nuttig?
Score 4
Disassemble it and resolder the left mouse micro switch. There's a many different suppliers, but average micro standard is universal. You can replace this with soldering iron or station.
Voeg je antwoord toe
Hyundong Sung zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 331
Altijd: 3,330
