Ga door naar hoofdinhoud
Reparatie en aanvullende informatie voor de Frigidaire GRFS2853A* koelkast—een vrijstaand koelkastmodel uit 2021 met automatische ontdooiing, zonder ingebouwde functies zoals een deurdispenser of ijsblokjesmachine. Deze pagina bevat informatie voor modelnummers die voldoen aan het patroon GRFS2853A*.
My refrigerator continues beeping
My refrigerator is cooling properly, freezing properly, making ice properly, but the light on the door continuously flashes and it keeps beeping overtime the light comes on. And it is constant. Power cycling it doesn't work. Pulling the power for over an hour doesn't work. Holding the Crush to reset it didn't work. We are about to lose our minds. Any ideas?
Is dit een goede vraag?
4 opmerkingen
Hi @tonyrogers
What is the full model number of the refrigerator?
What light is flashing?
door
GRFS2853AF0
It is the light in the door water/ice dispenser, under the temperature controls
door
@tonyrogers
Does the water dispenser work OK?
door
Everything works fine. Ice and water. Refrigerator is cooling and freezer is freezing. Just beeps and flashes the light.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @tonyrogers
I don't know.
The only thing that I can suggest is that you use the service data sheet to run the diagnostic tests and check if any errors are shown.
Maybe perform the tests for the door switches, dispenser paddle and lights first if no errors show when first entering diagnostic mode.
Hopefully it is not a control board issue.
If you find the problem and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to replace the part.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks. I will check it out.
door
Voeg je antwoord toe
Tony Rogers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 208
