Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de derde generatie Sony PlayStation 5 DualSense-controller. Te herkennen aan modelnummer CFI-ZCT1W en moederbordmodel BDM-030.
Audio jack not working
The audio jack was working fine until yesterday but today when fired up my console my wired JBL headphones wont connect. I tried with other controller and they seemed to work fine so not a headphone issue definitely a controller one... anyone know how to fix this?
Is dit een goede vraag?
Score 1
3 opmerkingen
Hi Sam!
Is the Dualsense it's firmware up to date? Just in case!
Do you use the controller on the PS5 or PC?
Do other headsets work or airpods or whatever?
Thanks!
door Deel
I use it with ps5 and yeah firmware is up to date๐Ÿ‘
door Deel
Okay! Thatโ€™s good! Do you have any other headset to test?? This would be the ultimate test.
In the worst case, you do need to replace the headphone jack.. this requires soldering and soldering experience!
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hey,
This is a common issue with PS5 controllers, I've attached a YouTube link for a couple quick diagnosis methods. Unfortunately if none of these methods get your controllers audio jack working again you may have to replace the audio jack which will require you to disassemble the controller and do some soldering.
Here is the YouTube link.
https://youtu.be/0goVWJZ_Ozo?si=A6N_OHSO...
Hopefully this helps, best of luck!
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thanks so much man cleaned it with alcohol issue resolved ๐Ÿ‘๐Ÿ‘
door Deel
All good, glad you got it sorted.
door Deel
Glad that it is working! Have fun gaming again!
door Deel
Voeg je antwoord toe
Sam Medadkar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 31
Afgelopen 7 dagen: 92
Afgelopen 30 dagen: 362
Altijd: 4,723
