Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De grootste en duurste smartphone van Apple uit 2019, uitgebracht op 20 september, beschikt over een 6,5-inch OLED-display, een camerasysteem met drie lenzen en een sterk verbeterde batterijduur. De opvolger van de iPhone XS Max.
Face ID is not available
After changing screen and earpiece assembly from IFixIt, the face id is not available. I put the old earpiece in, face ID works (but earpiece is still broke. I have tried two different (NEW-replacement) earpiece assemblies. I still get the Face ID Failure.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
This issue is 100% on Apple. They have paired the earpiece speaker assembly to the motherboard using a proprietary encryption algorithm. If the data from the front sensor assembly doesn't match that in the phone, it disables Face ID. No matter how many parts you buy, it will never work unless it is re-paired by Apple, who is the only one that can do it. And of course, it won't work with aftermarket parts, only genuine Apple parts.
In general the only way to get Face ID to work with a new earpiece speaker assembly is to buy a new screen from Apple and pay them to replace it. Their replacement screens come with the earpiece speaker assembly already attached, and as part of the repair process they will pair the new assembly to your phone, reenabling Face ID.
It's not all bad news though. If the problem is only with the speaker itself and nothing else is wrong with the assembly, it is possible to replace just the speaker and keep the rest of the assembly, meaning your Face ID will still work. Since the speaker isn't paired, replacing it doesn't affect your Face ID.
While there isn't an iFixit guide to that repair, I wrote a guide for the iPhone X based on a YouTube video that shows that same repair on your exact phone.
iPhone 11 Pro Max Ear Speaker and battery Replacement Keep Face ID Detailed - YouTube
However, the two phones are similar enough that the iPhone X guide will work for your phone as well. All you have to do is follow the iPhone 11 Pro Max Screen Replacement guide up to Step 26, where you flip over the earpiece speaker.
iPhone 11 Pro Max Screen Replacement - iFixit Repair Guide
Once you're there, skip to Step 29 on the iPhone X Earpiece Speaker Replacement guide and continue on from there.
iPhone X Earpiece Speaker Replacement Without Losing Face ID - iFixit Repair Guide
Doing this requires a very small spot of soldering, but otherwise is actually easier than replacing the earpiece speaker assembly, since you don't have to actually remove it from the screen.
Hope this information helps; let us know how it all turns out for you, as your experience may well help the next person who comes along with the same problem.
iPhone 11 Pro Max Scherm Afbeelding
Handleiding
iPhone 11 Pro Max Vervanging van het scherm
Moeilijkheid:
Gemiddeld
1 - 2 hours
iPhone X oorstuk luidspreker Afbeelding
Handleiding
iPhone X oorstuk luidspreker vervangen zonder verlies van Gezichts-id
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Matt Rowland zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 57
Altijd: 326
