starter replacement on 2004 jetta tdi
how many hours will it take to replace starter on 2004 jetta tdi
Is dit een goede vraag?
Paul,
The answer to this question will depend on your mechanical aptitude and your comfort level in completing a moderately difficult job.
Please check out this how to DIY remove and replace or repair thread from another forum. It's thorough and complete and I hope it helps you.
Come back and let us know if it worked.
Regards,
Frank
Was dit antwoord nuttig?
I did mine the other day. Your BEW TDI starter should only be replaced with a quality new, not remanufactured, starter. The higher compression of the engines likes to eat cheap starters. Heres a hint, local chain parts stores don't carry the starter you need. I won't plug a site to order from but buy it from the dealership or find in the tdi forums where people recommend ordering one from. Yes, they're expensive but you won't be doing it again in 9 months.
Time required is about an hour, probably less if you're comfortable under the hood. I found it was easiest to mostly work from the top side under the hood and removed the battery box and air box to get better access.
Be sure you know how to get the pigtail clips loose on the VW before you start, they're different than most other manufacturers. you release the clip THEN pull instead of most others are release the clip while pulling.
How do you get the tab on the starter do you pull it or? I can't get it out. I have a 2006 Volkswagen Jetta GLi
Question. ive locate removed and attempted to install a new starter for my 06 jetta 1.9L tdi and the electrical connections are different. My car has a male plug yet female slot (oval shaped) and the new starter is a square female plug yet male slot. so my connections wont connect and i have ne un successful at finding a different part number or starter to fix this. any thoughts?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 12,989
1 Opmerking
I have an 04 gli and I just replaced the starter but the engagement doesn't reach the flywheel? It needs to be at least 3 inches the new Bosch is about 2 3/4.
door Louis Roettger
