Ga door naar hoofdinhoud
How to replace the fans
Im trying to just replace one of fans that's vibrating and very loud. Im unsure if I can actually replace just one fan without replacing the whole cooling solution
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @copycap
Here's the hardware maintenance manual for the laptop.
Go to p.32 (38 of 66 pdf) to view the procedure to remove the Thermal module.
Looking at the parts list for the laptop (see image below) it seems as though you may not be able to replace just one fan as the replacement part comes as a complete module.
You could always check if there's any information printed on the fan itself, to see if searching online using the information gets results for just the one fan. Worth a try anyway.
If you decide to replace the module, search online using the part number only to find suppliers that suit you best.
Afbeelding
(click on image)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
CopyCap zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 51
Altijd: 530
