Ga door naar hoofdinhoud
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
How to solve red rig light problem of Xbox 360 console
How to solve red rig light problem in Xbox 360 console
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Does it just show a red dot? Or is there any pattern?
Anyway, most of the time it’s caused by the CPU/GPU. The solder under the IC’s is broken and this need to be fixed in order to get it working.
Here are some fixes you can try:
1: Reflow the CPU/GPU. This is the most easy and inexpensive fix to try. But most of the time temporary, so the issue can come back again.
2: Reball the solder. This is very difficult and requires special tools to get it done. But is very effective.
3: Replace the motherboard. Very easy to do so, but very expensive and hard to find.
If you need any guide or video, please let me know.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
MahadSheikh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 30
