Ga door naar hoofdinhoud
Uitgebracht in Japan op 12 december 2004, in Noord-Amerika op 24 maart 2005 en in Europa op 1 september 2005.
Non-functioning wi-fi switch on PSP1000
Hello,
I think the switch broke around 15 years ago, but there's no pressure on the physical switch on the left side of the console. Looking for advise or if there is even parts that are available before I start unscrewing anything
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi MattR!
This one is soldered on the motherboard unfortunately.
If you have soldering experience, you can replace it!
The part can be found here: https://store.richspsxparts.com/newinwls...
If you don’t know how to solder, it’s recommend to learn this first.
You can replace the motherboard, but this will be more expensive!
Please let me know if you need any guide!
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I have some soldering experience but mostly just some light plumbing and breadboarding in high school 10+ years ago. I think I’m up for the challenge though! A guide would absolutely be appreciated too!
door
Ah, then it will be a challenge, but it's fun to do!!
Guide: PSP 1000 moederbord vervangen
This guide is meant for taking the motherboard out. The part you need to replace, can be seen in the link where you can buy the part! If you need something more detailed, let me know! Good luck with the repair!!
door
Voeg je antwoord toe
MattR zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 72
Altijd: 764
