Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en demontage-informatie voor de Kobo Libra Colour eReader van Rakuten Kobo, uitgebracht in april 2024. Te herkennen aan modelnummers N428 of N428B.
Is this a broken screen?
Screen has suddenly appeared like this. it is still under warranty No knowledge of drops or impacts. Can anyone confirm that this is a physical damage to the screen and the fix is a screen replacement that wouldn’t be covered by warranty?
Afbeelding
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @alli23880
That is a crack in the screen. It will have to be replaced.
There's no warranty cover for that.
The relevant part of the manufacturer's warranty states in part: "The Limited Warranty described herein does not cover: (a) damage or malfunctions caused by accident, misuse, neglect, abuse, acts of God or other external causes; .....".
You can check what the warranty for the tablet shows for your location as not all warranties are the same.
Here's the ifixit Kobo Libra Colour (N428) Vervanging van het scherm guide that may help
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thankyou. I thought so too but wanted to be sure before buying the kit. Much appreciated. 😊
door Deel
and do you know where to get screens ? I have the same issue, but the kit is out of stock :(
door Deel
I have the same problem! Did anyone got the screen already? Was anyone able to repair it themselves?
door Deel
Voeg je antwoord toe
Alli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 753
