Ga door naar hoofdinhoud
Alles wat je nodig hebt om je iPhone zelf te repareren! iFixit biedt gratis reparatiehandleidingen en demontage-informatie voor elke telefoon, alsook de beste vervangende onderdelen en handigste tools.
36472 Vragen Bekijk alle
Can a li-on battery explode if you short circuit it accidentally?
I plan on repairing this phone's battery by soldering on a new one but I got afraid after reading that lithium ion batteries can explode when they are shorted?
My questions are simple:
will the li-on battery i bought on ebay have a protection on it?
Ipod variant:
http://www.ebay.co.uk/itm/170835137356?s...
will it give a huge harmfull explosion or what happens with a 1400 Mah battery when it is shorted?
will you notice something like this instantly or can it happen later when I have it in my pocket?
I have repaired the screen of another iphone 2g but this weekend I plan on fixing an Ipod and iphone 2g from myself and from a friend. I just read about this.
thank you for the advise!
rens
Is dit een goede vraag?
Score -1
1 Opmerking
I just read that there are many cases of exploding batteries... I am now afraid that my other iphone 2g will catch fire... I just replaced the screen yesterday and during the battery removal it got some minor dents and small disformations(nothing really serious..i think/hope)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I have not had one explode from accidentally short circuiting. I have had problems with the protection circuit failing after a short circuit. It is that circuit that is meant to maintain a safe operation. It limits the peak voltage of each cell during charge and prevents the cell voltage from dropping too low on discharge. Humidity, i.e. water damage etc is far more dangerous since it is the lithium that can react violently with any kind of moisture. Just like anything else, use care and common sense whenever you perform a repair. Hope this helps, good luck.In addition, the cell temperature is monitored to prevent temperature extremes.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
ok thanks alot! I have attached a picture with the battery that is in my iphone as can be seen it is slightly dented in the side and on the top(cover removal and battery removal).
is this anything serious because it looks OK to me.
http://i50.tinypic.com/33nxpbl.jpg
http://i47.tinypic.com/sdpu01.jpg
Thanks for your help it is really appreciated!!
door
should be okay for as long as it did not get punctured:-)
door
Voeg je antwoord toe
rens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 3,086
